Home » Audio » Craftsmen » Hey Wunhuanglo, it's true
Re: Damn good question! Who's got answers? [message #29164 is a reply to message #29162] Fri, 16 July 2004 10:15 Go to previous messageGo to previous message
Dean Kukral is currently offline  Dean Kukral
First, I am thinking along the lines of plain wood, not veneer - of course, if you use mdf, then you need to cover it to make it look good.
I have thought about my bedroom dressers, which have solid sides built up from strips about 5" wide. Also my kitchen table top is solid wood.
Why, then, do they go to all the trouble of making floating panels for cabinets and drawer bottoms, if not because of expansion? I suppose it is as you say - you can use solid wood if you know what you are doing.
I have a bunch of oak (two guys I used to work with and I bought it in 1990 from some guy who cut it and planed it; $100 - it is worth ten times that now :), and it would be nice to build my woofer cabinets with it, but I thought that would lead to problems. Do you think that it would work ok? I had planned on using it for my mid-horns, but oak plywood for the woofers.
Previous Topic: "Ready, Set, Shoot"
Next Topic: Must Have software for amp building
Current Time: Thu Nov 19 15:32:31 CST 2026
