Home » Audio » Craftsmen » Staples Redux
Staples Redux [message #29163] Fri, 16 July 2004 01:47
I had a bit of discussion with Mr. Martinelli about how staples have a nasty habit of taking wild right angle turns and poking out through the side of a panel.
I think I've found something out about that.
The staple seems to deflect in-plane (the plane the staple would lie in if you put it on a table). They almost never deflect out of plane. What I'm trying to describe is that they curl their ends like a cotter pin - the legs don't stay parallel and curve like railroad tracks following a "U" shape.
If you align the staple so that the plane of the staple is in the plane of the work, all the deflection stays within the work - no ends poking out.
The last four boxes I just built didn't have a single one poking out except when I forgot to change out for shorter staples and they went clear through :-^
Previous Topic: How to Flush-mount Irregular Shapes?
Next Topic: Need help with Polyurathane.
Current Time: Thu Nov 19 16:09:11 CST 2026
