Home » Audio » Craftsmen » Table saw recommendations?
Re: follow-up [message #29006 is a reply to message #28997] Wed, 31 March 2004 09:40 Go to previous messageGo to previous message
crazychile is currently offline  crazychile
Thanks for the photo, Bill.
I,ve been studying this for the last day or so and am a little confused by the photo. If you could clarify a couple of things for me I would appreciate it.
1. I build a new top surface for the saw out of plywood. (This fits over the existing surface).
2. In this new top surface is a slot where a perfectly square "L" fits and this is used to feed the piece of wood across the blade.
3. Do you also clamp a strip of wood on the other side of the blade to guide the varying sizes of wood?
Thanks for the info!
crazychile
Previous Topic: Tube PreAmp - Done! (almost)
Next Topic: For Beginners
Current Time: Tue Nov 03 10:24:20 CST 2026
