Home » Audio » Craftsmen » Any advice on working with exotics?
Re: You've entered the no carving zone ! [message #28888 is a reply to message #28887] Mon, 22 December 2003 13:58 Go to previous messageGo to previous message
I like the super hard and difficult woods as long as they don't need to be carved or require a lot of hand work. They "machine" very nicely with sharp tools and carbide is just about a must! Some of these difficult woods are getting close to how aluminum works. So with your woodworking tool things have to be sharp, sturdy and make light passes. Lots of the exotics are very oily, like coco bolo. You'll want to wipe it down with lacquer thinner or alcohol before making any glue joints. For this application I would also suggest enduring the misery and use a polyurethane glue.
All the problems are worth the time and trouble when the wood looks good in the end.
Previous Topic: Methods of work
Next Topic: Another question on router gear
Current Time: Sun Nov 15 17:52:22 CST 2026
