Home » Audio » Home Theater » Room size vs. Picture Size
Re: Room size vs. Picture Size [message #28679 is a reply to message #28640] Tue, 09 October 2007 23:37 Go to previous message
granch is currently offline  granch
I'd say go back to your motion picture theater experience. Where do you usually sit in the movie house if there is room to sit wherever you want? Visualize that and then sit in your intended seat at home and project that size on the other side of the room where you will be putting the set. Then measure what size that screen would be. I'll bet that unless you have a very small room, you will want a pretty big sized screen. Especially if you are buying an HDTV - and who would buy anything else today. Remember analog sets are going to be illegal (sort of) in just a few years (2?). At least you will have to buy a converter. If I remember right we sit about 13 ft from the screen of a 60 inch screen HDTV. We wanted a 70 inch but couldn't fit it in the room. We are NOT first row sitters in the movies- usually about 60-70% back.
-Dick
Previous Topic: What do I look for in a home system?
Next Topic: tvs that hook to your computer
Current Time: Wed Oct 28 08:56:21 CDT 2026
