Home » Audio » Home Theater » in-wall volume control 1 input into 2 speakers
Re: in-wall volume control 1 input into 2 speakers [message #28512 is a reply to message #28511] Sun, 24 July 2005 15:24 Go to previous messageGo to previous message
Investigate it just a little bit more when you have some extra time. If you're lucky, maybe the damage isn't as hard to repair as you think. Maybe the connection is bad at the wall plates, or near the end where you can get to it.
Check to see if the lines are shorted together with an ohmmeter. Then jumper one end and go to the other and check for continuity. This will tell you what kind of problem you are having.
If a staple went through, I would expect a short across the pair, not an open in one or both lines. It could cut through both conductors, shorting them together. But I doubt a staple would have cut the wire in half. If the line is open, I supose someone might have cut it with a saw or something. Maybe a finish carpenter cut clear through. But maybe the line was moved around enough while people were working that a connection broke loose. So I'd check the ends.
Previous Topic: speaker cable length for HT
Next Topic: A couple of general Home Theater questions if I may...
Current Time: Tue Sep 22 10:41:48 CDT 2026
