| Oops! [message #285] |
Tue, 09 March 2004 19:19  |
Messages: 19105 Registered: January 2001
Look at the Google links at the bottom of the page in the following post: Oops! I'm not really sure I'd want to be tied to that one.
| OK here's some snake oil for ya Wayne [message #286 is a reply to message #285] |
Wed, 10 March 2004 14:44   |
Bill Wassilak
Messages: 402 Registered: May 2009
Illuminati (1st Degree) |
>>What do you guys think of spikes? There cool if worn with leather.>>Do you think it helps pin the speakers to the floor? No only people. >>Do you use them only on hardwood floors or do some of you use them on carpeted concrete slabs? Depends on the mosh pit. >>What other floors would you use spikes for? See above. >>How about other accessories? Not really into body piercings, but different colored hair can be cool. >>Do you use risers for your cables? No only people or speakers. >>Alternative stuffing for your speakers? Haven't used animals or dead people yet, but heard animals can be used for room treatment if you have enough of them. >>What kinds of things like this do you think really work, and what ones do you think are nonsense? All of the above. Sorry couldn't help it :^) Bill W.
| Re: Oops! [message #363 is a reply to message #285] |
Fri, 02 April 2004 12:52   |
Bill Wassilak
Wayne more snake oil for ya, from live audio board. Heres the web site http://www.jadeaudio.com/facts.html When burning-in your new cables or auditioning new cables for your system, the following tips will maximize cable system performance and provide for the absolute shortest burn in period. Step One- The first 48 hours of play should be continuous- preferably with a cable burn-in disk. If you do not have a burn-in disk or one is not available, try music of a dynamic and ambient nature. Step Two- After 48 hours of uninterrupted play on a burn-in disk, switch to music(provided you were using a burn-in disk) for an additional 24 hours of uninterrupted play. If you were not using a burn-in disk, continue step one for an additional 48+ hours. Step Three- After 72 hours of uninterrupted play begin the listening process. You should know after 72 hours of burn-in whether or not a given cable design is going to be right for your system. When, after 72 hours, a cable seems "close," you may wish to just give it more time. If a cable does not perform to expectation, try a different cable from the same family or the same model from a different family.
| Re: Oops! [message #365 is a reply to message #364] |
Fri, 02 April 2004 13:58   |
Bill Wassilak
Yea heres a link to some good ones. http://www.geocities.com/CapeCanaveral/Hall/8701/Audio_BS.htm
