Home » Audio » Home Theater » Thoughts on Center Speakers??
Re: Thoughts on Center Speakers?? [message #28434 is a reply to message #28433] Fri, 13 February 2004 09:07 Go to previous messageGo to previous message
Personally, I think the choice of dialog channel is set a lot by the width of the room. Theaters naturally need a dialog channel because they are so wide. Similarly, a large spread between right and left forward speakers in a home theater creates a need for a dialog channel for the same reason.
For true dialog speakers, I think it's best to have the television immediately above or below the center speaker. It would be best to have the center channel immediately behind the television, which is possible with an acoustically transparent screen. But I doubt many people are running projectors so that's rarely an option. Short of having an acoustically transparent screen with speakers behind it, I think it's best to have the television right above the dialog speaker. When the midrange/tweeter is just under the televison, the illusion works pretty well.
If the room isn't wide and the right and left channel flank the television anyway, I don't think there's much to be gained by having a discrete center channel. A virtual center is fine in that case. I run a pair of speakers flanking the television to create a virtual center. That's a good solution in my living room; There's a wide soundstange and definitely no trace of any missing area between them.
Previous Topic: Poll - How long?
Next Topic: Opinions on Toshiba & Sharp DVD recorder/players (w/HD)
Current Time: Thu Oct 29 09:53:16 CDT 2026
