Home » Audio » Pro Sound » assistance designing live-sound setup for band
Re: assistance designing live-sound setup for band [message #28396 is a reply to message #28395] Wed, 06 June 2007 11:28 Go to previous messageGo to previous message
Q1: I would go with a T48 DR250 combo rather than the DR200, because you can cross the T48 at 100HZ and the DR250 would reach down that low. Where as the DR200 won't.
Q2: For the basement gigs and small to midsize rooms, the 25x40 size your talking about, 900 watts total should be ok, but that's using both A+B outputs, but 900 watts won't cut it outdoors.
Q3: The question here is how low an impedance can you drive out of each output?
Q4: If you can't drive 2 ohm's out of the mixer your maybe asking for smoke out of output A. Output B would be fine because that's a 4 ohm load with 2 monitors. The second part of that question wouldn't work either because the mono output just ties A+B output together.
Q5: Nope not from a single cabinet. Folded horns it's all about throat area,horn length and especially mouth area.
Q6: You only need 1 active x-over for everything.
You didn't break any rules of the board, ask away that's why were here, to help out.
HTH
Bill W.
Previous Topic: digital recorder
Next Topic: Fender Bassman 70
Current Time: Sat Oct 17 10:50:55 CDT 2026
