Home » Audio » Pro Sound » Terminating balanced lines
Re: Terminating balanced lines [message #28369 is a reply to message #28356] Fri, 02 July 2004 11:21 Go to previous messageGo to previous message
martinleewin is currently offline  martinleewin
The weak link, mechanically, is where the small wires can flex near the termination. I would solve it by soldering barrier terminal block style jumpers (inverted seagull shape) to a copper PC board. Drill holes for the wires to be soldered and larger holes to strap the cable jacket to the board. Then cut and peel (or etch if you are that handy) away the copper in between the conductors.
If the screw terminals are in a line the screwed jumpers can hang off one edge of the board. A window in the middle of the board would be needed with a triangle screw pattern and is stronger in either case with terminals coming in from two sides to resist flexing. Adjacent connectors on the chassis might limit outer dimensions of our windowed termination board. I dunno how much room you have to work with.
You could even solder a right angle PC mount XLR connector instead of wires and tie wraps for a really professional job.
Good luck and keep those wires from dangling,
Martin W.
Previous Topic: audix microphones room 15
Next Topic: Eric Barbour interview at Synthtopia.com
Current Time: Fri Nov 13 09:11:56 CST 2026
