Home » Audio » Pro Sound » Peavey speaker questions
Re: Peavey speaker questions [message #28338 is a reply to message #28336] Mon, 07 July 2008 12:13 Go to previous message
GraemeG is currently offline  GraemeG
On these, the "low" jack has normally closed contacts which connect the crossover into circuit when the socket is unused. When the biamp sockets aren't normally used, the closed contacts can develop corrosion which leads to a resistive contact, which produces heat and weakens the spring of the contact , compounding the problem until it no longer works. It will just need a new socket soldered into the PCB, but you will have to get the correct type (they are available aftermarket) - there are many variations of phono sockets.
Previous Topic: need help with amp
Next Topic: ampeg vt-22 head
Current Time: Fri Nov 20 07:36:05 CST 2026
