Home » Audio » Pro Sound » Hornsub shootout
Re: Hornsub shootout RESULTS - DR250 [message #28082 is a reply to message #28081] Sat, 15 October 2005 13:36 Go to previous messageGo to previous message
Leland Crooks brought a pair of DR250 speakers that he hoped to test. So we had a little time at the end of the day and we ran a couple sweeps.
Specifications:
Weight: 40 lbs
Dimensions: 22" x 22" x 22"
Power handling: 150wrms
Impedance: 8Ω
Frequency range: 100Hz - 16kHz
Sensitivity: 105dB/W/M
Max Output: 125dB/M
Distortion at 100 watts: 5%
http://prosoundshootout.com/Measurements/DR250_Impedance.gif
DR250 Impedance
Impedance is 8Ω, so 28.28v input is 100 watts. Since we measured 10 meters away, the values correspond to both 2.83v/1M and 1W/1M.
http://prosoundshootout.com/Measurements/DR250_28v.gif
DR250response at 10 meters with 28.28v input (2.83v/1M)
The blue line is SPL, and the violet line shows distortion. Average distortion is 25dB under the fundamental, which is about 5%. Since measurement was taken at 10 meters, add 20dB to find SPL at 1 meter. With 100 watts input, the 10 meter measurement works out the same as 1 watt input measured at a distance of 1 meter.
http://prosoundshootout.com/Measurements/DR250_Impulse.gif
DR250 impulse response
http://prosoundshootout.com/Measurements/DR250_Step.gif
DR250 step response
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Fri Oct 23 07:27:03 CDT 2026
