Home » Audio » Pro Sound » Update to DIY site
Re: horn race [message #28035 is a reply to message #28009] Sat, 15 January 2005 20:30 Go to previous messageGo to next message
pgolde is currently offline  pgolde
A Skilsaw, a straight edge and 2 c clamps is all you need. oh, and the wood, and maybe a drill, and some glue, a few screws. Forget the joiner and other fancy tools, your plans dont require them. Use polyurathane adhesive, it expands to fill in your skilsaw imperfections.
Re: horn race [message #28036 is a reply to message #28035] Tue, 18 January 2005 00:28 Go to previous message
Ive got a drill,sander and skilsaw. I find the assortment of glue products boggling,il try to find polyurathane adhesive!
I guess il need a 110cm straight edge, a good piece of timber will work.
Cheers
Mike.e
Previous Topic: Selection Help
Next Topic: tube amp output power question
Current Time: Fri Nov 13 05:09:50 CST 2026
