Home » Audio » Pro Sound » Adire Tempest horn sub
Re: Size matters [message #27947 is a reply to message #27946] Tue, 07 September 2004 15:28 Go to previous messageGo to previous message
If you could get a 4 inch driver with an Fs of 35Hz and six inches excursion it would have the ability to outperform a 15 in an equally sized enclosure. Right now that isn't possible. But someday?
What I can say for sure is that using a ten I get the same performance as a 15 or 18, or 21 for that matter, from a considerably smaller box. On the other hand, if the boxes are the same size with equal mouth sizes they have the same radiating area, while the longer horn made possible by the smaller driver and smaller chamber required to house it gives a longer pathway for a lower Fc and a higher acoustical impedance for both lower extension and higher SPL.
Previous Topic: B12 and PSD3003
Next Topic: Bass speakers
Current Time: Wed Nov 04 17:01:42 CST 2026
