Home » Audio » Pro Sound » Adire Tempest horn sub
Re: Adire Tempest horn sub [message #27941 is a reply to message #27940] Tue, 07 September 2004 07:18 Go to previous messageGo to previous message
The main problem here is that horns work best when you use a small driver with a large horn. This design does the opposite, using a large driver in a box that's too small to allow a proper development of the horn. Back when this design came out in the early '70s it was useful, since back then you didn't have long throw high BL tens and twelves, and you had to use a fifteen by default; as limited as the design was it was better than a reflex box in terms of extension and SPL, so it had value in pro-sound where a 50Hz F3 is useful. But todays drivers have pretty much rendered the whole idea of using a 15 in a horn loaded box to the heap. Smaller drivers allow more horn from the same size box, with an attendant increase in performance.
Previous Topic: B12 and PSD3003
Next Topic: Bass speakers
Current Time: Wed Nov 04 17:01:32 CST 2026
