Home » Audio » Pro Sound » is 200w/side enough.
is 200w/side enough. [message #27918] Mon, 26 July 2004 06:01 Go to next message
Andy G is currently offline  Andy G
I do small bands mainly in pubs and small clubs. I am currently running a pair of speakers using a 2 Eminence Kappa 12's,
this is usually enough for my purposes.
http://users.tpg.com.au/users/gradds/twinkappa1.jpg
There have been a couple of time recently where I thought some extra down the bottom end would be nice, and would ease the load on the main bins. I would run them from the sub out of the Behringer FBQ 3120, through a separate amp.
I have a pair of the following drivers that I am not really using,
http://users.tpg.com.au/users/gradds/jaycar%20PA15.jpg
and was considering using them to provide the extra low end.
Just not sure if they will make much difference??
PS... [message #27919 is a reply to message #27918] Mon, 26 July 2004 06:02 Go to previous messageGo to next message
the boxes would be designed to sit under the main speakers.
Re: PS... [message #27920 is a reply to message #27919] Mon, 26 July 2004 10:07 Go to previous messageGo to next message
Yeah, I'm with you on this one. You might be able to put them in an EBS cabinet or maybe a bandpass. But without running the numbers, my guess is that they are really intended for large sealed boxes. That means EBS would probably work too, but I'm not sure you're going to get a lot of deep bass out of them.
On the other hand, below 100Hz, a subwoofer placed underneath near the mains is going to sum pretty well, so any additional output will help. If you already have the speakers, it seems like it couldn't hurt to give them a try. Just don't blow 'em, and if they don't work well in this application, you can use them for something else.
The Jaycar PA15 [message #27921 is a reply to message #27920] Mon, 26 July 2004 15:14 Go to previous messageGo to next message
is a really smooth driver, I have them in a 15" + horn box at the moment, but generally find myself using then twin kappa 12s because of the large difference in headroom. ie the twin kappa goes lots louder, being a 4 ohm box helps too!!
I will probably try the Jaycar PA15s as some bass boost just to see if it works. The other option is buying some new 15" drivers, but I'm on student wages at the moment:-((
Those Eminenece Magnum HO's look rather nice in a smallish box !!
Re: The Jaycar PA15 [message #27922 is a reply to message #27921] Tue, 27 July 2004 03:49 Go to previous messageGo to next message
The Magnums are nice, give 'em a try!
its a funding thing...... [message #27924 is a reply to message #27922] Tue, 27 July 2004 07:59 Go to previous messageGo to next message
...I'm on student allowance at the moment !!!! aghhhhhhh!!
Re: its a funding thing...... [message #27925 is a reply to message #27924] Tue, 27 July 2004 08:48 Go to previous messageGo to next message
Gotcha. I understand completely.
You might look at the Omegas, as they sound good and cost a lot less than Magnums. No shorting ring, but they sound very good, better than most without flux stabilization. I think it may be because they make the static flux symmetrical.
gunna try the Jaycars... [message #27927 is a reply to message #27925] Sat, 31 July 2004 07:44 Go to previous messageGo to next message
120L tuned to 42Hz with a slight rise through 50-60 .
I'll use the Behringer FBQ 3120 "sub out" at about 80-120 hz for a start, see what happens I guess !! Shouldn't cause too much problem for the Jaycars, I hope ! If I blow them up, I sould be able to replace them with either a kappa pro15 or a magnum 15ho.. they all model in boxes that are reasonably similar !
Re: is 200w/side enough. [message #27933 is a reply to message #27918] Fri, 27 August 2004 03:32 Go to previous messageGo to next message
Murdy is currently offline  Murdy
200 watts is enough for about 10 or 20 people, that's about it.
If so [message #27990 is a reply to message #27933] Mon, 08 November 2004 00:34 Go to previous message
is 400w/channel enough for 20 or 40people ?
and 800w/channel enough for 40 or 80people...
Id be more interesting in
-System sensitivity
-Boundarys
Previous Topic: Bandpass subs
Next Topic: Looking for plans for...
Current Time: Fri Oct 16 19:59:19 CDT 2026
