Home » Audio » Pro Sound » Paging BillF, GraemeG and SwollenL - Massive hornsub
Re: 100dB/watt at 20 Hz is overkill. [message #27865 is a reply to message #27863] Mon, 15 March 2004 14:04 Go to previous messageGo to previous message
DanR is currently offline  DanR
If I understand you are saying the deepest bass should not be horn loaded. That squares with what my tech says, because he doesn't want harmonics from the deepest bass to enter the horn. I'm told that increases distortion since mostly the harmonics are boosted by the horn. My thinking is that if we have a very high quality woofer it will alleviate the problem. Maybe a better idea is to keep the bottom end separate from the midbass though and remain horn loaded from the midbass up.
Previous Topic: Manley Labs
Next Topic: jbl 2243 theile/smalls
Current Time: Wed Nov 04 00:28:05 CST 2026
