Home » Audio » Pro Sound » Low distortion basshorns
Low distortion basshorns [message #27856] Sat, 06 March 2004 06:16 Go to next message
DanR is currently offline  DanR
I run a sound company and we have JBL speakers. The tops are all horn loaded but the subs are dual 18's. I'd like to use labhorns or something similar, but I don't like the LAB12 woofer. It makes the subs powerful but unmusical. What woofers having a Faraday ring and built for horn loading can be used instead?
Re: Low distortion basshorns [message #27857 is a reply to message #27856] Mon, 08 March 2004 00:50 Go to previous messageGo to next message
swollen libido is currently offline  swollen libido
You might want to look at this subwoofer. Talk about amazing, in a horn sub, all the more so.
Re: Low distortion basshorns [message #27858 is a reply to message #27856] Tue, 09 March 2004 04:16 Go to previous messageGo to next message
GraemeG is currently offline  GraemeG
In what way are they "unmusical"? Could this be because you are so used to the distortion present in your old 18s that clean bass sounds unnatural? I would think that any sub speaker that can work well in a horn at high levels without getting near Xmax will sound "different" to what most of us are used to....
Cheers
Re: Low distortion basshorns [message #27859 is a reply to message #27858] Tue, 09 March 2004 07:13 Go to previous messageGo to next message
It's hard to put my finger on it, best I can say is that I want a 'tighter' sound. Seems like better woofers will do better distortion wise and being in a horn even lower distortion and higher output. What do you think?
Re: Low distortion basshorns [message #27860 is a reply to message #27857] Tue, 09 March 2004 07:14 Go to previous messageGo to next message
Thanks, good suggestion. I'll look into it.
Re: Low distortion basshorns [message #27869 is a reply to message #27857] Mon, 15 March 2004 18:01 Go to previous messageGo to next message
it models up well for a 40hz horn anyway,didnt get around to doing 30hz
Re: Low distortion basshorns [message #27914 is a reply to message #27856] Thu, 01 July 2004 20:04 Go to previous message
johnny mc grory is currently offline  johnny mc grory
hi have you ever tried mc kenzie or heard of them i personaly rate them A1 speakers www.bkelectronics.co.uk have a look
regards johnny.
Previous Topic: Paging Wayne Parham
Next Topic: www.AX84.com
Current Time: Fri Nov 13 08:30:36 CST 2026
