Home » Audio » Pro Sound » Subwoofer help
Subwoofer help [message #27842] Mon, 11 May 2009 01:10 Go to next message
Robb is currently offline  Robb
I am looking to purchase a B-52 MX-18S or a JBL JRX 118S subwoofer.
Any advice on these or other subs in this $400 price range
Thanks
Re: Subwoofer help [message #27843 is a reply to message #27842] Tue, 12 May 2009 23:46 Go to previous message
My advice would be to purchase more than one of whatever you choose. By placing a few bass sound sources around the room, you can make bass response smoother. The peaks and dips caused by standing waves in the room are averaged out - where a valley in response from one sub lies, a peak forms from another to average out the field. This works great in bars and other small and medium sized rooms where direct radiating subs like you've asked about would be most appropriate.
Outdoors or in very large rooms like theaters and auditoriums, I'd suggest using basshorns grouped together. That's an entirely different situation, where you need more acoustic power. You also wouldn't want to spread them around like you would in a smaller room. Outdoors, it's better to group the subs together.
Previous Topic: Prosound Shootout
Next Topic: question from a Fender Princeton 65 user
Current Time: Sun Nov 01 12:22:29 CST 2026
