Home » Audio » Pro Sound » Removal of Transformer From Old Jensen Speaker
Removal of Transformer From Old Jensen Speaker [message #27610] Thu, 28 August 2008 05:55 Go to next message
Eric Marangone is currently offline  Eric Marangone
I have an old Jensen Alnico 10 that came out of a console stereo. It has an old transformer on it and some wires coming out of the magnet.
I am wondering how to connect it to my guitar amp. Should I remove the tranny and cut some wires?
Re: Removal of Transformer From Old Jensen Speaker [message #27611 is a reply to message #27610] Thu, 28 August 2008 16:00 Go to previous message
Sounds like you have a speaker with a field coil instead of a fixed magnet. Does it have four wires coming from it? If so, it is most likely a field coil speaker. You'll need a power supply for it because one pair of wires is the field coil, which is an electromagnet. This is used in place of a fixed magnet. The voice coil works just like speakers with a fixed magnet, signal current is applied through it and this causes the cone to move.
Previous Topic: finding a better amp
Next Topic: ??????Can any of you tech's help?????
Current Time: Wed Nov 04 01:19:44 CST 2026
