Home » Audio » Pro Sound » crate keyboard amp question
crate keyboard amp question [message #27573] Thu, 24 April 2008 17:29 Go to next message
Jan Garber is currently offline  Jan Garber
I have a 10 or 12 year old crate keyboard amp. The switch went out on it.
I'm wondering if it can be replaced with a generic rocker-switch, or whether it will require a specific replacement part?
Re: crate keyboard amp question [message #27574 is a reply to message #27573] Mon, 28 April 2008 12:38 Go to previous message
Any switch will work provided the voltage and current rating are appropriate and the number of poles are right. It is nice if the part will physically fit without having to modify the cabinet.
If your switch moves in only two positions, look for 2T (or DT). If it switches one circuit, it's 1P or ST. If two circuits, it's a 2P or DP. A switch with two positions and two sets of contacts is usually refered to as a DTDP switch. Switches are also rated by voltage and current limits on the contacts. If yours is rated 250V and 10A, get a part that meets or exceeds that.
Previous Topic: DIY?
Next Topic: earth problem?
Current Time: Fri Oct 23 03:08:46 CDT 2026
