Home » Audio » Pro Sound » VOX ac30 The cloth
Re: VOX ac30 The cloth [message #27565 is a reply to message #27430] Tue, 11 March 2008 03:00 Go to previous message
colton is currently offline  colton
Mine did the same. What you need to do is get super glue and needle nose pliers. Pull the gold band off. First you stretch the cloth upward with the pliers, hold it there by pushing your finger against it, with your other hand put super glue in the slot. Then with the needle nose pliers, use the tip to push the cloth down over the glue and hold. Repeat. hope it helped
Previous Topic: Orange Amps? or Marshall Amps?
Next Topic: Amps not getting any signal...Help please!
Current Time: Mon Oct 05 23:12:44 CDT 2026
