Home » Audio » Pro Sound » What's a good light speaker?
Re: What's a good light speaker? [message #27561 is a reply to message #27556] Sat, 08 March 2008 13:01 Go to previous message
Gary- is currently offline  Gary-
Hi, I'm brand new to the forum. I saw your post and thought that I would suggest a Jensen Neo. I have two amps that use them. One has a 10" and the other has a 12". These speakers are very good once they are broken in, however, can sound a little harsh at first. The 10" speaker took more time than the 12" to break in. I'm not sure if it was due to cone size, wattage, or a combination. The amp with the 10" speaker is a 15 watt amp and is just 21 lbs. and the other is a 60 watt amp which is around 31 lbs. Both are tube amps.
If you can find a Neo that is broken in, take a listen and see if it fits what you are looking for.
Previous Topic: Marshall Artist 4203
Next Topic: newbie amp question
Current Time: Wed Nov 04 00:42:17 CST 2026
