Home » Audio » Pro Sound » Tsl 601 No Sound!
Tsl 601 No Sound! [message #27116] Fri, 12 August 2005 13:28 Go to next message
GuitarCrazy is currently offline  GuitarCrazy
Hi there!
I am completely new to the forum but would greatly appreciate some help regarding my amplifier.
Im a little worried as I have not seen any posts so far about the problem that I have with my amp. I'am completely new to the tube amp world so I'm hoping that this is easily fixed!
I've just replaced the preamp valves with a set of Electro-Harmonix 12ax7's. But now I'm not getting any sound from the amp. All the valves are glowing nicely, the speaker is connected and definitly still works, the channels switch ok, but just no sound.
Does anybody know what the problem might be?
I wish I hadnt touched it now, it was working fine before I replaced the valves!
Thanks.
Re: Tsl 601 No Sound! [message #27117 is a reply to message #27116] Fri, 12 August 2005 17:00 Go to previous messageGo to next message
Does it work if you put the old tubes back in?
Have you checked any of these tubes with a tester?
Re: Tsl 601 No Sound! [message #27118 is a reply to message #27117] Sat, 13 August 2005 02:49 Go to previous messageGo to next message
Hi,
I put the old tubes back in last night, and now the only the clean channel works.
No Ive not checked the tubes, how do you do that?
Re: Tsl 601 No Sound! [message #27119 is a reply to message #27118] Sat, 13 August 2005 03:09 Go to previous messageGo to next message
Get a tube tester from eBay. Make sure it works and has all the charts. They don't cost a lot and you'll probably be really glad you got it.
Re: Tsl 601 No Sound! [message #27120 is a reply to message #27119] Sat, 13 August 2005 03:13 Go to previous message
Thanks. Il have a look at them, I just hope it is just fualty valves.
Previous Topic: Phantom power / ribbon mics
Next Topic: Mesa Boogie Single Rectifier Problem
Current Time: Wed Sep 16 10:46:24 CDT 2026
