Home » Audio » Pro Sound » Speaker replacement and problem with Laney VC30
Speaker replacement and problem with Laney VC30 [message #27104] Thu, 14 July 2005 04:40 Go to next message
Anonymous
Hi everybody,
I've recently bought a used Laney VC30 112. I've just bought an Eminence Legend GB12 to replace the old stock speaker. Now putting it in the speaker gives a fuzzy noise on certain notes played, mainly Cs (especially played on A-string). Can anyone help, please?!
Don't bother with answering, seems I have found the problem [message #27105 is a reply to message #27104] Thu, 14 July 2005 04:57 Go to previous messageGo to next message
Anonymous
Re: Don't bother with answering, seems I have found the problem [message #27106 is a reply to message #27105] Thu, 14 July 2005 07:03 Go to previous messageGo to next message
What was the problem? Was it not tightened down onto the baffle? Was something vibrating?
Re: Don't bother with answering, seems I have found the problem [message #27108 is a reply to message #27106] Thu, 14 July 2005 10:04 Go to previous messageGo to next message
Anonymous
Two things: speaker has great depth, was too close to power tubes. Made them vibrate. And one had a broken solder joint, which was therefore constantly moving. Fixed the soldering and removed the card board stuff from the speaker frame so that I gained some space between speaker and tubes.
Thanx for reply!
Re: Don't bother with answering, seems I have found the problem [message #27109 is a reply to message #27108] Thu, 14 July 2005 11:53 Go to previous message
Gotcha, that makes sense. Glad you found it and thanks for letting us know.
Previous Topic: question about bass amp head
Next Topic: linear amps???
Current Time: Fri Nov 06 01:44:23 CST 2026
