Home » Audio » Pro Sound » slaving amps!
Re: slaving amps! [message #26998 is a reply to message #26996] Fri, 04 March 2005 19:33 Go to previous messageGo to previous message
Aaron Merrill is currently offline  Aaron Merrill
Hey brent,
I'm no expert on the 5150, so does it have a preamp out that will not automatically cut the signal to the power stage? If so, go for it. tone from the 5150 + power from the other amp. You are essentially running a mini-PA from your amp this way. - do you just need this for shows? You may want to simply mic the cab (which has a bit of sway over tone as well) through PA if that is the case.
aaron
Previous Topic: marshall valvestate vs65r no sound
Next Topic: Switchable power section plexi
Current Time: Sun Oct 25 22:49:00 CDT 2026
