Home » Audio » General » alighnments
Re: alighnments [message #26806 is a reply to message #26805] Sun, 05 December 2004 19:39 Go to previous messageGo to previous message
Open baffles aren't my thing, but I can speak to the issue of radiating angle. I'd say the transition from 4π to 2π radiation will be more abrupt on the square panel than on the rectangular one. If a driver is centered on a round baffle, the transition will be the most abrupt because the distance to the edge is the same in all directions. The square baffle is close, because four sides are equidistant. If the driver is offset on the baffle, the transition will be more gradual. So the shape of the baffle and the position of the radiator will set the rolloff shape of the low frequencies due to the sharpness of this transition.
Previous Topic: MARANTZ 2325
Next Topic: Audio Critic
Current Time: Fri Oct 16 21:18:32 CDT 2026
