Home » Audio » General » 2nd Channel on a EICO ST-40
2nd Channel on a EICO ST-40 [message #26615] Sun, 18 March 2007 22:43 Go to next message
DW Barnnhard is currently offline  DW Barnnhard
I am having problems with my recently acquired EICO ST 40
the 2nd channel is dead when I have the unit switched to stereo.
When I select reverse the speaker in the 2nd channel works.
When I select Mono both speakers work. I have a center speaker connected which works and is connected as indicated in the instructions.
Any suggestions. DWB
Re: 2nd Channel on a EICO ST-40 [message #26616 is a reply to message #26615] Mon, 19 March 2007 10:22 Go to previous message
When you select "reverse", does the balance control still work? If so, then the second channel is working and the problem is probably limited to the selector switch. If not, you may have a dead channel.
Previous Topic: Houston Audio Society
Next Topic: Anybody know where I can get some VLSI chips replaced?
Current Time: Tue Nov 03 12:04:39 CST 2026
