Home » Audio » General » Lansing 825 driver's power supply
Lansing 825 driver's power supply [message #26367] Sat, 13 August 2005 13:48 Go to next message
Keisuke Aoyagi is currently offline  Keisuke Aoyagi
Hi,I have one Lansing 825 driver but don't know what is the proper DC
voltage to feed the magnet field coil of this unit. On the label it says 220V 25watts, which I think the feeding AC voltage for the power unit amp.If anyone knows about the correct DC voltage and ampere for 825 field coil driver, please let me know. Or if anyone have the proper power unit for the Iconic Speaker system and may sell it, please let me know.
Re: Lansing 825 driver's power supply [message #26368 is a reply to message #26367] Sat, 13 August 2005 20:44 Go to previous messageGo to next message
You might contact Bill Hanuschak at Great Plains Audio. He may know the answer.
Re: Lansing 825 driver's power supply [message #26369 is a reply to message #26368] Sat, 13 August 2005 22:21 Go to previous messageGo to next message
Thank you very much for your advice.Keisuke Aoyagi
Re: Lansing 825 driver's power supply [message #26373 is a reply to message #26367] Tue, 30 August 2005 16:49 Go to previous messageGo to next message
Steve Schell is currently offline  Steve Schell
Hi Keisuke,
It sounds to me as though you have a Lansing 285, the large format compression driver with the radial slit phasing plug. Is this the case?
The ratings stamped into the metal badge would be for DC voltage operation of the field coil. 220VDC was the most common field supply voltage for these drivers, being used routinely in the Lansing Shearer Horn systems. 25 watts dissipation in the field coil is also correct for these drivers. Field coils were also wound for other supply voltages, so you should be sure before applying voltage.
I have a couple of 285 drivers in my collection rated to run on 220VDC. Their field resistance measures about 2,500 ohms.
Calculating the correct supply voltage when the DC resistance and dissipation is known is an Ohm's Law calculation. Please contact me here or at stfrsc@juno.com if you would like assistance with this.
Re: Lansing 825 driver's power supply [message #26374 is a reply to message #26373] Tue, 30 August 2005 18:20 Go to previous messageGo to next message
Hello Steve,Thank you very much for your kind advice.Yes, it is 285, not 825, and I also found the feeding DC voltage mentioned on the metal label.It says 220V. May I ask you one more question, how do you get such high DC voltage for feeding ? Is there any AC/DC converter for this ratings ?
Keisuke Aoyagi
miloptik2@catv296.ne.jp
1-18-8, Asahigaoka, Yotsukaido-shi,chiba-ken, Japan 284-0024
phone 0081-43-432-9074
Re: Lansing 825 driver's power supply [message #26375 is a reply to message #26373] Wed, 31 August 2005 04:08 Go to previous messageGo to next message
Hi Steve,
Good to see you here. Last I heard, you were making your own compression drivers. How did that work out? What are your latest projects?
Wayne
Re: Lansing 825 driver's power supply [message #26376 is a reply to message #26374] Fri, 02 September 2005 23:21 Go to previous messageGo to next message
Hi Keisuke,
When these drivers were used in the theatre systems, a dedicated field supply was part of the equipment. It powered all the field coils in the system, which could be up to six compression drivers and woofers in total. The circuit was simple; power transformer, rectifier tube(s), choke and filter capacitor. The old field supplies usually still work fine when they can be found, but are quite scarce these days.
Generally I use a bench type variable voltage DC supply, like the ones made by Lambda, Kepco and others. One needs to be found with the correct voltage range and adequate current rating. If you would like to build an original style field supply, let me know and I'll send you a scans of the schematic diagram.
Re: Lansing 825 driver's power supply [message #26377 is a reply to message #26375] Fri, 02 September 2005 23:28 Go to previous messageGo to next message
Hi Wayne,
Rich and I are still working steadily on our driver designs, and hope to be able to offer them for sale within a few months. We are about finished with the design of our DS-1428 mid / high frequency compression driver, which is based on the RCA MI-1428B of the late 1930s. We are also developing the DS-1448 bass compression driver, similar in design but scaled up in size. Our horn designs have been evolving as well. Stay tuned!
Re: Lansing 825 driver's power supply [message #26378 is a reply to message #26377] Sat, 03 September 2005 00:36 Go to previous message
Sounds interesting. I'm eager to see your drivers. All the best!
Previous Topic: fall audio get together??
Next Topic: Yes absolutely
Current Time: Thu Nov 05 08:32:44 CST 2026
