Home » Audio » General » Initial Listening Impressions of Yamaha ca-1010
Getting Qts out of the way [message #26208 is a reply to message #26207] Fri, 24 September 2004 23:06 Go to previous message
It does help indeed, MArtin! You are basically sugesting that I get the Qe equal (or close) for each circuit. That makes sense. This will certainly allow a comparison of simply the distortion effects and other frequency anomalies, versus the effects the amp impedance has on performance.
I will insert maybe a 2 ohm resistor to increase teh Qe of the SS amp speaker circuit.
Good suggestion from you again!
thanks to you & Wayne for guiding hobbyists like me as I continue my fun hobby of figuring out what exactly does sound better, and what is snake oil!
thanx
-akhilesh
Previous Topic: Vacuum Tube Valley #21
Next Topic: Budget Isolation Base
Current Time: Mon Nov 23 01:24:00 CST 2026
