Home » Audio » General » Anyone have experience wth the Yamaha ca-1010
Re: Thanks Wayne & John [message #26172 is a reply to message #26171] Wed, 01 September 2004 09:59 Go to previous messageGo to next message
Hi John,
That's a very good idea. I have a way to record CD's, and I have done that several times. But I have a couple of tape decks that are very nice too, and so I often times make copies of records the old school way. Honestly, they last longer than my home recorded CD's.
My Rega 2 is still around and I've been listening to it a lot lately. I've been doing a lot of little "mini-reviews" in the Movies and Music forum, and they've all been from albums I've played on the Rega.
Wayne
Re: Thanks Wayne & John [message #26173 is a reply to message #26172] Thu, 02 September 2004 08:20 Go to previous messageGo to next message
Wayne, your saying the tapes last longer than the CD's?
Re: Thanks Wayne & John [message #26174 is a reply to message #26173] Thu, 02 September 2004 08:36 Go to previous messageGo to next message
Yes, absolutely. I have tapes that I made in the early 80's that still sound great, even after repeated plays. Of course, they're sensitive to heat and even more to magnetism, so those can kill a tape or at least the recording on it. And there is physical contact between the tape and head, so there will be wear and it will eventually wear out.
Recordable CD's can conceivably be much more robust, but in practice, my experience has been that they aren't. Even with delicate care and nothing touching the surface, after few months and/or a few plays, most recordable CD's I've had begin to skip. I'm sure someone can point to examples of recordable media that is a little more durable than that, and possibly some decks that are better than others. But I think the symptoms I've described are pretty common and most would report similar experiences with recordable CD's.
Archie difital files on a hard drive [message #26175 is a reply to message #26174] Thu, 02 September 2004 08:48 Go to previous messageGo to next message
HI Wayne,
Good point about CDs skipping. I agree!
At some point, it will probaby start making sense for all of us to buy a CD and first archive it on a hard drive.
-akhilesh
Re: Archie difital files on a hard drive [message #26176 is a reply to message #26175] Thu, 02 September 2004 09:06 Go to previous messageGo to next message
Yeah, that's a great idea. In fact, I predict hard disk A/V recorders wil become much more popular this decade.
Re: Archie difital files on a hard drive [message #26177 is a reply to message #26175] Thu, 02 September 2004 11:47 Go to previous messageGo to next message
Good thing I kept my reel-to-reel. What do you all think about sattelite radio? I have heard it and think standard, good quality FM sounds better.
Re: Archie difital files on a hard drive [message #26178 is a reply to message #26177] Thu, 02 September 2004 12:06 Go to previous messageGo to next message
never heard satellite, john. I did buy a 25 year old Kenwood FM tuner that sounds darn good, unmodded, (through one of my tube amps & speakers) with a cheap wire for an antenna.
-akhilesh
Re: Archie difital files on a hard drive [message #26179 is a reply to message #26178] Thu, 02 September 2004 17:48 Go to previous messageGo to next message
Akilesh; You bring up a good point there, the part about "unmodded".
For some time now I have begun to believe that mods for mods sake may not be all it's cracked up to be. Some things I have heard both mod and not mod and I kind of liked the not mod better.
Now in the case of Dyna Stereo 70 where there is obvious design flaws that when corrected make definate improvements, some Fisher gear I have heard sounded better with out the mods.
And some Eico amps I have heard with only the old electrolytic caps replaced with stock values of inexpensive caps sounded better bfore the mods were done. So I believe the jury is out concerning all the benefits of mods. What do you think?
J.R.
Re: Archie difital files on a hard drive [message #26180 is a reply to message #26179] Fri, 03 September 2004 05:37 Go to previous messageGo to next message
HI John
The tuner I have is the kenwood kt-7500. I believe, based on reading about it at FMtunerinfo.com & corresponding with some folk who have had it modded, that some mods do benegit it sonically. Mainly, i think they are the power caps mod (as you mentioned) and in one case, shortening the signal path. ANother mod involves changing the opamp, which should make a difference.
I think there are some mods that work, and many that don't (since you asked for my opinion...always a dangerous thing to do!). I don't really know about coupling caps....i am planning to put auricaps on my kit tube amp (pusxh-pull 6bm8 k-503 from AES) amp, but will it make a difference? I don't know. I have never yet been able to hea the difference with a power cord. I think most speaker cables sound the same (I use transparent becuase they seem to lower my noise floor and bring out more detail). I do use little gel bases from bright star...tehy are cheap, and i figure tey can;t hurt. HAve they made a difference? not really sure, but if any vibrations do exisit, I am sure they do a good job of absorbing them. I mainly use them with the tube amps to reduce microphonics. I also use cheap tube dampers.
Overall, i am now evolving, after about 2 years in this hobby, into just being happy with what I have, and not restlessly trying for more. Just enjoying the music, and once in a way buying vintage stuff, like the yamaha amp I just bought...
what do you think about mods?Which ones do you use?
-akhilesh
Re: Archie difital files on a hard drive [message #26181 is a reply to message #26180] Fri, 03 September 2004 14:44 Go to previous messageGo to previous message
Good reply. I did not mean to suggest that mods are of no value but re-reading my own post I see I may have done that. I really mean't to express the thought that mods are not always beneficial especially with vintage gear. I always replace vintage electrolytics only because you have too since they dry out. I like carbon-comp resistors but lots of others don't and I understand why, they are soft and lacking detail. I think of all the mods to vintage gear replacing connections and coupling caps does the most good.
Some of the recent mods I have done is to replace the rectifier diodes in the AES pre-amp with Hex-Freds. That helped as I stated in the post on the tubes forum. I have replaced the entire power supply in my Dyna 70 and it sounds better.
I am familiar with that group you mention concerning Tuners. I have a Sherwood tube tuner and I noticed they thought highly of that model. I called them on the phone to discuss mods and they told me not to touch it as long as it worked and sounded good.
I have the AES pre-amp but I don't recall they made a 6bm8 based amp, which one is that?
How you like that Yamaha and which speakers sound good with it. I know you have the Single Driver Fosteks and the Klipschorns. I respect your opinion thats why I ask, so isn't the point of both of these speakers to refuse brute power, but to sound good with low power well controlled tubes, triode
SE in fact. Wasn't the Klipschorn voiced with a Brook SE amp?
I have a question that I have spent some time considering, when you put passive baffle step correction or frequency contour circuits in line with Single Drivers why not just bite the bullet and add a tweeter? What would be the gain in using one driver if you have to use a xover after all? I know about the point source thing but if you listen from 10 feet away whats the difference? I am rambling I see, thanks AK for any reply you have,J.R.
Previous Topic: MarantzCD 5001
Next Topic: GPAF Info
Current Time: Tue Sep 22 22:03:20 CDT 2026
