Home » Audio » General » mc 60 choke
Re: mc 60 choke [message #26122 is a reply to message #26121] Tue, 11 May 2004 23:21 Go to previous messageGo to previous message
If it's a power supply filter choke, you can go with the rule that "bigger is better." The higher the inductance, the better. Same with wire diameter since that sets current carrying capacity.
If you're looking for a direct replacement part then hopefully someone else will chime in. But if you're looking for specifications of a suitable replacement, then go with the biggest coil that will fit, both in inductance and current carrying capacity.
Previous Topic: Roll call
Next Topic: FRD... of possible interest
Current Time: Thu Nov 12 14:33:32 CST 2026
