Home » Audio » General » hi -anyone know what tweeters were used in the monitor audio MA4 speakers
hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26098] Wed, 07 January 2004 09:44 Go to next message
Alan Watkins is currently offline  Alan Watkins
these are old speakers,circa 1978. The tweeter is 70mm.
any help appreciated
the bass drivers is a b200 sp1039 kef unit
but i dont know who made the tweeters
thanks
Alan
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26099 is a reply to message #26098] Tue, 20 January 2004 17:32 Go to previous messageGo to next message
I did some looking and couldn't find them. 'Spose you might post or E-Mail a photo? Be sure and include any other information you might have, such as physical dimensions. I think I can help you out with that info.
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26100 is a reply to message #26099] Wed, 21 January 2004 01:46 Go to previous messageGo to next message
hi thanks for the reply - heres a pic of the tweeters
they are 70mm in diammeter
http://homepage.ntlworld.com/quad303/images/tweeter.jpg
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26101 is a reply to message #26100] Wed, 21 January 2004 02:24 Go to previous messageGo to next message
You're saying that the magnet is 70mm diameter, yes? I expect the dome is about 25mm across, yes?
Can you show a photo of the back? Also, what does the tweeter mount on to?
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26102 is a reply to message #26101] Wed, 21 January 2004 10:15 Go to previous messageGo to next message
hi thansk for the reply, yes the dome is 25mm and the magnet 70mm.
heres a pic of the rear of the unit and the 'mounting plate'
theres a 4 digit number, 7810 I think. But it seems to be a serial number rather than a code number,because the other good tweeter has a different number stamped on it.
cheers
alan
http://homepage.ntlworld.com/quad303/images/tweeter2.jpg
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26103 is a reply to message #26102] Wed, 21 January 2004 18:11 Go to previous messageGo to next message
What do you think about substituting another 1" dome tweeter for this one? I think I would probably replace both tweeters from both speakers if a stereo pair, but I think you might find this to be an acceptable solution. I'd probably keep the original units if I swapped them out, just in case.
Also, have you checked with local speaker repair shops to see if they could just replace the diaphragm? Is there a local repair shop in your area?
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26104 is a reply to message #26103] Thu, 05 February 2004 13:52 Go to previous messageGo to next message
thanks again for the info. I got a set of Seas SEAS 25TFFc (soft dome)tweeters, which are nice. I dont know if its me but I did prefer the original units. I have since found out that the tweeter is made by Audax, HD13D34 part no.
I have contacted the only place I can find the part listed in Denmark to see if they can ship to me. Im not sure if theres a repair shop in my area, but thats another option for me.
cheers
Alan
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26105 is a reply to message #26104] Thu, 05 February 2004 17:28 Go to previous messageGo to next message
Sounds like you did your homework. That's good information for the archives, so thanks for the follow-up post.
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26134 is a reply to message #26105] Sat, 19 June 2004 22:23 Go to previous messageGo to next message
Fred is currently offline  Fred
What a joke! I'm looking for exactly the same thing!!!
I have a pair of MA 4 that I bought in '77 and had my grandkids do some finger pokin' while I forgot that the covers were off!!!
Anyway,,, just searching the internet and I come across this; what a godsend... thanks guys (and girls)
Re: hi -anyone know what tweeters were used in the monitor audio MA4 speakers [message #26259 is a reply to message #26105] Mon, 14 March 2005 13:49 Go to previous messageGo to previous message
Peter McCabe is currently offline  Peter McCabe
Tweeter was an Isophon (German) modified with damping material within the dome... giving it it's distinctive yellow colour. I used to own a pair back in the 70's. Believe me MA has not improved much on them (in terms of musical naturalness) since then.
Previous Topic: speakers
Next Topic: LoneStarAudiofest.com
Current Time: Thu Nov 05 01:54:31 CST 2026
