Home » Audio » Radio » My find!!!
My find!!! [message #25961] Wed, 12 September 2007 11:15 Go to next message
Crystal is currently offline  Crystal
I found a Zenith 11S474 console radio at a yard sale this weekend past! Woohoo! I have been looking for an antique radio for ages to start restoring and pick up as a hobby. I heard that the rubber wiring is likely rotted, so I imagine that will be my first step.
Any advice? Congrats! :D? LOL
Re: My find!!! [message #25962 is a reply to message #25961] Thu, 13 September 2007 08:31 Go to previous message
Your radio likely will need capacitors, especially those in the power supply. If the radio doesn't work, or if it hums, replace capacitors first. Believe it or not, the capacitors are more likely to be bad than the tubes.
Tubes aren't usually very expensive for these old radios, so you might buy a set. If one of your tubes is bad, you can swap them one at a time to find out which one it is. Put the originals back in one at a time to see which ones work, and keep them. Tubes last a long time, so don't throw them away unless you're sure they're bad.
If your radio has wiring with rubber insulation, replace with cloth. You can get a spool of this kind of wiring, as well as tubes and other parts at Antique Electronic Supply. Also check BOIAudioworks for tubes.
Previous Topic: Wards Airline 62.2714 radio / phono combination
Next Topic: RCA Model 98-BT
Current Time: Mon Nov 23 00:28:31 CST 2026
