Home » Audio » Radio » Clinton Radio Schematics
Clinton Radio Schematics [message #25753] Sat, 10 September 2005 09:24 Go to next message
Spencer CS is currently offline  Spencer CS
I have two Clinton radios, models 194 and 153, that I need schematics
on. I have had no luck finding anything on these models, and have
found very little about the Clinton Mfg. Co. Can anyone help? CS.
Re: Clinton Radio Schematics [message #25754 is a reply to message #25753] Sat, 10 September 2005 22:00 Go to previous messageGo to next message
Describe the radio and list the tubes it uses. Perhaps it has an OEM chassis, and a schematic can be found for it.
Re: Clinton Radio Schematics [message #25755 is a reply to message #25754] Sun, 11 September 2005 08:55 Go to previous messageGo to next message
Hi Wayne. Both are wood,tabletop and same tube lineup:
6d6,6c6,43,25z5. The 153 is bw/sw with a k55c ballast.
the 194 is bw only with a k55b ballast. My problem is
with the electrolytics. Both have unmarked rectangular
paper multi-caps. The 153 has 7 wires;3 black, 4 brown.
The 194 multi-cap has been changed at some point as it has
6 leads with only 5 connected and the leads have been
taped at mid-wire connections. I am new to old radios
and don't want to try to guess at these values. The 194
is listed in Steins Tabletop Vol.1, p-48. Thanks for your
response. Spencer CS
Re: Clinton Radio Schematics [message #25756 is a reply to message #25755] Sun, 11 September 2005 21:51 Go to previous messageGo to next message
Power supply electrolytics can be made arbitrarily large. Most are only 20uF-50uF but pretty high voltage, usually 250v or 450v. You can swap them with polypropylene or electrolytic capacitors, the bigger the better.
Re: Clinton Radio Schematics [message #25757 is a reply to message #25756] Mon, 12 September 2005 06:51 Go to previous message
Thanks a bunch Wayne. You mentioned OEM mfg's which I hadn't thought
of. I went through a number of Riders and found maybe 50 different
schem's using that lineup. I didn't find an exact match but several
were close enough to give me an idea of values. I have tried to
measure other multicaps after removing them but most were nowhere
near the stated values. I'm learning. Thanks. Spencer CS
Previous Topic: Bendix Radio Schematic
Next Topic: General Electric Wooden Radio Grill
Current Time: Thu Nov 05 09:38:35 CST 2026
