Home » Audio » Radio » Grille cloth - how to fasten to cabinet?
Grille cloth - how to fasten to cabinet? [message #25616] Tue, 04 January 2005 19:25 Go to next message
Mark Williams is currently offline  Mark Williams
Hi,
I got some reproduction grille cloth for the Emerson radio I posted the photo of earlier.
What glue should I use to attach this to the wooden cabinet?
Mark
Re: Grille cloth - how to fasten to cabinet? [message #25617 is a reply to message #25616] Tue, 04 January 2005 23:44 Go to previous messageGo to next message
Hi Mark,
Just use wood glue; A white glue will work just fine. Cut the cloth large enough that it can be glued well within the open area so none of the glue wicks into the visible fibers.
Wayne
Re: Grille cloth - how to fasten to cabinet? [message #25618 is a reply to message #25617] Wed, 05 January 2005 17:40 Go to previous messageGo to next message
Hi Wayne,
OK, thanks for your help!
Regards,
Mark
Re: Grille cloth - how to fasten to cabinet? [message #25625 is a reply to message #25617] Thu, 13 January 2005 10:37 Go to previous messageGo to next message
dcriner is currently offline  dcriner
I've had good luck with 3M Photo Mount spray adhesive. It's primary use is for mounting artwork. It is tacky and it doesn't wick. I looks wet when it sprays on, but then disappears.
Cool website! [message #25626 is a reply to message #25625] Thu, 13 January 2005 11:46 Go to previous message
That's a really cool website you have. Thanks for the link!
Previous Topic: Stewart Warner Model 01-6G1
Next Topic: Atwater Kent Model49 Speaker Horn
Current Time: Thu Nov 05 03:28:16 CST 2026
