Home » Audio » Radio » Need schematic -- RCA
Need schematic -- RCA [message #25606] Fri, 03 December 2004 20:39 Go to next message
Mark Williams is currently offline  Mark Williams
Hi,
Would anyone have a schematic for an RCA Victor model 3-X-521? It's a small table radio supposedly from 1951. Serial no. is U 124327.
It works, but hums fairly loudly. I see one burned resistor but I cannot make out the color code. When I know the value, I'll replace this bad resitor and hope the hum stops. Is it likely to be the fix?
Would appreciate any & all help.
Mark
Re: Need schematic -- RCA [message #25609 is a reply to message #25606] Sat, 04 December 2004 13:55 Go to previous message
You probably need power supply capacitors. Look for capacitors inside the radio with values around 8uF to 20uF. You'll probably find two or three; Replace them with polypropylene 250v caps and the hum will probably go away.
I found a schematic that may be for your radio on Rider volume 14. It has 35Z5, 50L6, 12SA7, 12SK7 and 12SQ7 tubes. That was a very common tube set for RCA radios. I have a couple of chassis like those myself. One of mine was just like yours when I got it - Working but with a lot of hum. I replaced the power supply caps and it was much quieter.
Previous Topic: Hi Wayne
Next Topic: montgomery ward airline mod#GMJ-2024
Current Time: Tue Oct 27 16:09:00 CDT 2026
