Home » Audio » Radio » Loose cap on top of tubes
Loose cap on top of tubes [message #25569] Wed, 15 September 2004 14:28 Go to previous message
John White is currently offline  John White
Hi all, nice site!
I just bought a great little tube radio and it works good too! The thing is there are two tubes inside with connectors on top that seem loose. There is a wire attached and it's pretty snug. I'm concerned because the little cap on top is loose. You can rotate it back and forth a little bit. The tubes work, or at least the radio does, but I think it is odd that these caps are loose. Is that normal? Do I need new tubes?
Thanks in advance,
John White
Previous Topic: 300 ohm vs 75 ohm
Next Topic: Stereo FM Tuners
Current Time: Tue Oct 27 18:13:24 CDT 2026
