Home » Audio » General » Subs
Subs [message #25319] Sat, 07 August 2004 12:16 Go to next message
Bob77 is currently offline  Bob77
Is it better to build a box for subs or let the trunk be the box? I heard the trunk is better because it is big. As long as it doesn't rattle and buzz that is.
Re: Subs [message #25320 is a reply to message #25319] Sun, 08 August 2004 08:21 Go to previous messageGo to next message
BLS is currently offline  BLS
It depends on the speaker, but a trunk is bigger than needed for most 10's and 12's. On the other hand, sealed speaker boxes can be larger than needed. Ported speakers can't, so if you use your trunk as the box, don't port it unless you know for sure the speaker can work in that large of a box.
Re: Subs [message #25321 is a reply to message #25320] Mon, 09 August 2004 10:15 Go to previous message
If you use the trunk as the box then you can't tune the enclosure for the best possible response. You also can't just toss any old driver into a trunk mount or again it won't work (I assume that by trunk mounting you mean mounting the driver through the rear package shelf; all driver require some sort of baffle top separate the front and rear driver waves). The best bet is a tuned enclosure mounted in the trunk, or a more exotic kick panel arrangement, just as long as the enclosure and driver are properly matched.
Previous Topic: sharing info
Next Topic: Cone versus compression driver midrange
Current Time: Fri Nov 13 05:48:05 CST 2026
