Home » Audio » Measurement » Neutrik Microphone
Re: Neutrik Microphone [message #25252 is a reply to message #25251] Wed, 23 January 2008 09:06 Go to previous messageGo to previous message
That's a good question, and I think you might want to contact NTI and ask them. I would guess it would probably work, but it may affect its performance. That would bring your measurements into question, which makes it sort of missing the point to even use it. So I'd call NTI.
There is one other thing you might consider. The phantom supply is provided through series resistors on pins 2 & 3, usually 1kΩ to 10KΩ each pin. You could put shunt resistors across each pin from 2-1 and from 3-1 to reduce the phantom voltage. Be sure they are perfectly matched, equal value resistors. You could put them on a microphone cord or on a little pigtail adapter. I wouldn't go smaller than 1KΩ to reduce the effect of line impedance but I don't think you'll have to go that low. If the phantom supply source impedance is 4.7KΩ. then a 4.7KΩ resistor in shunt will cut phantom voltage in half. You can always connect the resistors across pins 1-3 and 2-3 and measure the voltage across those pins to make sure they're between 10v and 30v before connecting the microphone.
Previous Topic: Soundcard worries
Next Topic: Measuring Mmd
Current Time: Fri Oct 16 19:28:35 CDT 2026
