Home » Audio » Room Acoustics » Best speakers
Best speakers [message #25092] Sat, 08 September 2007 13:31 Go to next message
Gilipsie is currently offline  Gilipsie
We still have the old type speakers with wires, but we have been considering upgrading them. The other half though that wireless was the way to go. I'm not too sure and would love your input.
Re: Best speakers [message #25093 is a reply to message #25092] Wed, 19 September 2007 19:23 Go to previous messageGo to next message
willyable is currently offline  willyable
I'm not understanding what you mean, like are you talking about speakers for your computer or are your talking about speakers for your surround sound. I didn't know that speakers were wireless. I thought all of them came with wires. I must have been mistaken. But I did find some wireless, speakers called acoustics research AW-871 main stereo speakers. So I guess there are some wireless speakers out there. I need to upgrade myself.
Re: Best speakers [message #25094 is a reply to message #25093] Thu, 27 September 2007 12:29 Go to previous messageGo to next message
sacback is currently offline  sacback
If I'm not mistaken Bose are wireless speakers. There are a number of different type os speakers that you can get that are wireless.Check this link out
http://www.bestbuy.com/site/olspage.jsp?id=abcat0205009&type=category
Re: Best speakers [message #25099 is a reply to message #25094] Thu, 04 October 2007 21:05 Go to previous messageGo to next message
I like Bose actually, they are a nice set of speakers. The sound that the give off are excellent. They sound extra crisp when they are inbetween some book son a book shelf.
Re: Best speakers [message #25107 is a reply to message #25099] Fri, 05 October 2007 12:14 Go to previous messageGo to next message
They are a bit sexpensive to though but I mean if you want quality then they would be your best bet.
Re: Best speakers [message #25113 is a reply to message #25107] Mon, 08 October 2007 00:46 Go to previous messageGo to next message
Look at TAD, JBL, Klipsch and others like that.
Re: Best speakers [message #25116 is a reply to message #25113] Mon, 08 October 2007 12:41 Go to previous messageGo to next message
Klipsch are good speakers, those were my first set when I first got my surround sound.
Re: Best speakers [message #25121 is a reply to message #25116] Sat, 13 October 2007 10:01 Go to previous messageGo to next message
How much do those speakers run? I'm not trying to spend over a couple hundred for speakers.
Re: Best speakers [message #25125 is a reply to message #25121] Mon, 15 October 2007 13:34 Go to previous messageGo to next message
You aren't going find them anywhere under a couple of hundred unless you get them used or refurbished.
Re: Best speakers [message #25128 is a reply to message #25125] Fri, 26 October 2007 09:26 Go to previous messageGo to previous message
Crystal is currently offline  Crystal
You can check out ebay and see if you can find them on there. I have run across alot of pro audio equipment on ebay that were in great shape and fairly priced.
Previous Topic: Recording room for voice overs
Next Topic: Looking for a Visual
Current Time: Sun Oct 25 10:33:39 CDT 2026
