I was told that you should corner your subwoofer instead of centering it. I dont know how true that is but honestly with it centered or cornered, it all sounded the same to me.
I learned that if you want your surround sound to sound just like that, you have to surround your room with your speakers correctly. Thats the key word I guess. "surround."
That is true, you want to stick with the corners as well as the top of the walls. I have my small speakers on the top of my ceilings and some of my speakers are located in the corners of my room.
Wayne Parham Messages: 19105 Registered: January 2001
If I may make a suggestion: Use CARA to help analyze the room before deciding on speaker placement. That will help you understand the modal behavior, energy distribution and tonal balance throughout the room. Then if you're really serious, use something like Smaart to measure the room after setting the system up. You can adjust the placement of each speaker and identify trouble spots, perhaps adding dampers and absorbent materials in strategic places to fine-tune the room.
That is new to me, I didn't think it was that serious or could get that serious rather. Is that what they use when putting theatres together or building a theatre room in homes?
The closer you put the subwoofer to a wall, the stronger the bass output becomes. When it is moved into a corner, bass output is maximized. However, sometimes you will get a "booming" sound instead of a nice even tone if it is too close. Adjust the subwoofer until you are satisfied with the sound.
Adveser Messages: 434 Registered: July 2009 Location: USA
I can definitely hear the bass coming from a direction generally. I put my sub in the centre when I had one. My speakers could output more bass than the room size allowed (35hz/the room was less than ~30(1)ft required to make an undistorted waveform, so that sub didn't last too long in the setup because i'm not much of a fan of modulating the bass frequencies, and correct me if i'm wrong, but that is what i've been taught happens when you hear a waveform the room can't accompany or use headphones.
The best way to do it is to use more than one and wire them in stereo. A Boston record with a Hammond B-3 is really going to reveal the limitations of "omni-directional" bass. The situation is being overstated IMO. Bass has direction and you can bet it's important...the mids and treble are just more important and get the priority. I think it is a serious myth that it "doesn't matter" when dealing with bass. hard panned stereo death metal blast beats make this very apparent.
