Home » Audio » Room Acoustics » Metal wall studs?
Metal wall studs? [message #25016] Wed, 25 August 2004 10:57 Go to previous message
This winter (and spring and summer and fall and...)I'll be finishing my basement. My music / HT room will be 8.5' x 13.5' x 22' and I would like to use metal studs. Are there any negatives to this? I'll will be double sheeting the walls with 1/2" or 5/8" gypsum wall board. Studs will be set 16" on-center with cross bracing and insulation between studs.
Is this going to be bad (too much wall flex.) The reason for using metal studs in the first place is cost - pure and simple. Should I just cough up the extra cash for wood studs or am I going to be OK?.....Colin
Previous Topic: Floor/room playing with
Next Topic: SSS
Current Time: Sat Oct 31 21:23:33 CDT 2026
