Home » Audio » General » Inexpensive Small Headphones?
Inexpensive Small Headphones? [message #24908] Wed, 02 May 2007 08:58 Go to next message
Ricardo is currently offline  Ricardo
I need to replace the headphones I use with my MP3 players, and I was wondering if anybody here had any suggestions.
I don't use ear buds, and the headphones I was using that came with my Sony personal CD player have finally broken.
Re: Inexpensive Small Headphones? [message #24911 is a reply to message #24908] Tue, 08 May 2007 11:33 Go to previous messageGo to next message
Check out Sennheiser. They make good inexpensive headphones.
Re: Inexpensive Small Headphones? [message #24912 is a reply to message #24908] Tue, 08 May 2007 14:30 Go to previous messageGo to next message
randle is currently offline  randle
Go to sony.com or ebay and you'll find some really good ceap headphones for like 12 dollars. And they are of good quality.
Re: Inexpensive Small Headphones? [message #24914 is a reply to message #24911] Fri, 11 May 2007 08:22 Go to previous messageGo to next message
Thanks for mentioning that. When I think of Sennheiser, I think of fairly expensive microphones.
Re: Inexpensive Small Headphones? [message #24915 is a reply to message #24914] Wed, 16 May 2007 12:23 Go to previous messageGo to next message
Panasonic sell headphones as well you may want to check them out, they aren't expensive at all and they work well.
Re: Inexpensive Small Headphones? [message #24921 is a reply to message #24908] Fri, 18 May 2007 08:27 Go to previous messageGo to next message
busybeehelpers is currently offline  busybeehelpers
I usually find inexpensive ones at the local music stores. They usually work well but are less than $15.
Some of the best I've heard [message #24928 is a reply to message #24908] Wed, 30 May 2007 23:06 Go to previous messageGo to next message
are the Koss KSC75's. You can pick them up for less than $20 if you shop around and they sound very, very good! You can also do some mods to them to improve them a bit.
Do a search over at www.headfi.com in the DIY section for all the info you'd ever need.
Re: Inexpensive Small Headphones? [message #24944 is a reply to message #24915] Wed, 12 September 2007 11:43 Go to previous messageGo to next message
Gilipsie is currently offline  Gilipsie
You can get a paid off panasonics for about 64 dollars on Amazon. Which isn't bad at all because alot of times they run almost 100 bucks.
Re: Inexpensive Small Headphones? [message #24955 is a reply to message #24944] Sat, 06 October 2007 14:35 Go to previous message
willyable is currently offline  willyable
Depending on the type of panasonics you are talking about. They can run all the way up to hundreds of dollars. But I'm sure not too many of us dab in that type of buying power.
Previous Topic: FM Modulator
Next Topic: dell plasma tv
Current Time: Sat Oct 31 18:29:26 CDT 2026
