Home » Audio » General » Why do my headphones hiss?
Why do my headphones hiss? [message #24854] Mon, 07 March 2005 16:15 Go to next message
itza_newbie is currently offline  itza_newbie
Hey all! I'm brand new here and already have a question. I bought a brand new set of Grado SR-60 headphones. As soon as I plug them in, I get a lot of hiss, even though the volume is all the way down. What is that, and is there any way to get rid of it? I'd hate to think I wasted my money on headphones nicer than my cheapies that didn't hiss!
Thanks so much for any advice you can offer!
Re: Why do my headphones hiss? [message #24855 is a reply to message #24854] Mon, 07 March 2005 21:13 Go to previous messageGo to next message
The hiss is coming from the source or the amp.
Re: Why do my headphones hiss? [message #24856 is a reply to message #24855] Tue, 08 March 2005 07:06 Go to previous messageGo to next message
Is there any way to get rid of it? A filter or something?
-Thanks!
Re: Why do my headphones hiss? [message #24857 is a reply to message #24856] Tue, 08 March 2005 07:32 Go to previous messageGo to next message
If you're lucky, you'll make the 35,000th post. That'll cure it!
If not, you'll probably want to find another amp and/or source. That's the only way to get rid of the noise. Since the hiss is coming from the source, whatever you might do to remove the noise will also remove some of the music, taking away all the treble. It would make your music sound very bad.
Re: Why do my headphones hiss? [message #24858 is a reply to message #24854] Tue, 08 March 2005 12:40 Go to previous messageGo to next message
Have you tried plugging your headphones into another amp or portable to make sure it is the headphone? I'm assuming when you use your "cheapies" in the same amp, they don't hiss?
Re: Why do my headphones hiss? [message #24862 is a reply to message #24858] Fri, 01 July 2005 14:32 Go to previous messageGo to next message
sam9 is currently offline  sam9
Best way to get rid of the hiss is to use a good headphone amplifier that you connect to the line-level outputs of you preamp. Or pre-outs of an integrated amp/ reciever. Or to the output of you CD player, RIAA preamp etc.
Re: Why do my headphones hiss? [message #24886 is a reply to message #24854] Mon, 02 April 2007 21:26 Go to previous messageGo to next message
randle is currently offline  randle
you are either playing them too loud and or there is some type of surge that has burst inside of your speaker.
Re: Why do my headphones hiss? [message #24898 is a reply to message #24858] Thu, 12 April 2007 18:16 Go to previous message
Ok maybe I should have said that but at the same time I tried that and it was still hissing so I figured that it was the headphones.
Previous Topic: Jensen Imperial Find
Next Topic: Off topic: I have my own theme song now
Current Time: Fri Nov 13 06:02:06 CST 2026
