Home » Audio » Speaker » MG 1 power requirements?
Re: MG 1 power requirements? [message #24751 is a reply to message #24748] Tue, 16 May 2006 15:19 Go to previous messageGo to previous message
jpvanson is currently offline  jpvanson
I've a pair of MG-Is as well. Great speakers that introduced me to good audio and ultimately spoiled my taste for mediocre speakers.
The MG-I is rated at 82dB/w/m at 5 ohms input. However, the truly magnaplanar design as these are offer up a nearly resistor flat impedance curve so the 5 ohms is easier to drive tham equivalent sensitivity 8ohm speakers. Depending upon the size of your room, you can get by satisfactorily with that 50wpc amp of yours. I used a cheap 45wpc amp for a few months and found the combination very enjoyable. I've run everything from a 15wpc 6BQ5 Fisher SA-16 amp up to ~200wpc solidstate and found them to sound good regardless. However, this is in an ~15'x16' room (technically larger thanks to an L-shaped design).
If you room is a great deal larger then definitely look for a high-current amplifier more than the watts. Maggies respond more to current than other speakers and you will appreciate the results.
Good luck.
- JP
Previous Topic: Need advice on cabinet choice for JBL E120
Next Topic: Using Car Speakers With Your Hi Fi
Current Time: Mon Nov 02 11:55:20 CST 2026
