Home » Audio » Speaker » SI Sound Pads
Re: SI Sound Pads [message #24645 is a reply to message #24644] Mon, 27 December 2004 16:16 Go to previous message
I saw this thread a while back, but never got around to responding.
One idea I had was to mount them on shrink film. The speaker's panel could be made out of a 1x2 frame, simialr to a knitting frame, with the film mounted in the frame sandwich. The film could then be shrunk with a hot air dryer or larger air heater, for more uniform shrinkage.
I've worked with this type of film in the past when I was in the packaging industry, and there are all kids of chemistries used. Also, you can get uni- or biaxially shrink characteristics. The film comes in rolls of 36" wide and miles long. You might do a google search to see if a film supplier can give you free samples. Look for films such as PVC, PVDC, PET, OPS or PE. A quick test might be to pick up a window winterizing kit from a local home store. This is PE (polyethylene) and has marginal dimensional shrink, but as long as you can get it tight it would be a fun experiment. Other films have up to 80% shrink.....Colin
Previous Topic: Improve Bass
Next Topic: FE166ES-R Get your pre-order in..
Current Time: Tue Nov 17 11:21:46 CST 2026
