Home » Audio » Speaker » Does you experience apply to horn loading?
Does you experience apply to horn loading? [message #24439] Thu, 05 June 2008 19:05 Go to previous message
Aaron D is currently offline  Aaron D
RE the “A” vs. the “B” models: I see your point in choosing the A. I mentioned B since it is priced so much lower (when buying large quantities). I wonder if the B’s could be modded like the A’s to achieve the same C-to-C. In any event the horn concept could be applied to either and in that sense the original topic is unchanged. Out of curiosity what is the final C-to-C of your modded A version?
From what I can tell it seems as if all of your conclusions are based on your experience using this tweeter in a non-horn app. The meat of my OP was to figure out if comparing the same driver in a horn vs. non-horn app is a valid comparison or if certain parameters change when a horn is added (and if so what and to what degree w/ a 90 degree 3” wide horn in this case). I do know that FR is extended on the low end (you can see that in the graph). The impedance is also affected (which is an indication of lower Fs). The only real factors left are excursion and distortion from what I can gather. If the “magic” of horns keeps all of those in check then it looks like we could have a practical option for the tweeter line (or the start of one at least if this needs to be hashed out further).
I knew from the outset that this would be horn discussion more so than one centered on LA’s and I debated whether or not to even ask it on this forum. With the cost of building a low compromise tweeter line being one of the most of discouraging factors of building a LA I wanted to make sure the topic got referenced where others w/ similar apps could see it. Furthermore, I know Wayne is pretty knowledgeable about horns and he would probably be helpful no matter where the discussion took place.
Later,
Aaron
Previous Topic: Why are air core coils?
Next Topic: Jensen G610
Current Time: Fri Oct 16 16:26:24 CDT 2026
