Home » Audio » Speaker » The Ultimate Array Conclusions
103db/watt midrange and tweeter ribbons..bass line array [message #24416 is a reply to message #24415] Fri, 23 May 2008 01:04 Go to previous messageGo to previous message
Scooter is currently offline  Scooter
A 0.4" wide x 90" long 5.8u Al tweeter ribbon with 1T could reach 103 db/watt
A 3" wide x 90" long 8u Al midrange riggon with 0.6T could reach 103 db/watt
Custom DIY bridge topology amps would be necessary to direct drive the 0.1-0.2 ohm midrange ribbon. 32 watts Class-A would seem adequate, and a high current delivery challenge
Five 15" woofers in parallel could match the 103 db/watt of the ribbons. A high 0.94 Qts like the Lambda Dipole woofers would save some baffle boost power. Should reach below 30Hz in most rooms.
Since this is Ultimate...an array of sealed bipole woofer stacked pairs would pressurize the room for 16Hz-30Hz.
Previous Topic: My ART Arrays
Next Topic: Question about magnetic flux modulation
Current Time: Tue Nov 03 10:46:05 CST 2026
