Home » Audio » Speaker » The Ultimate Array Conclusions
Re: Forgot the obvious - CSS WR125ST (14 ohms) [message #24411 is a reply to message #24409] Wed, 21 May 2008 10:14 Go to previous messageGo to next message
I agree with darkmoebius. This is a versitile and good sounding driver. It obviously isn't expensive enough to impress the audiosnobs of the world, but its midrange clarity, lack of breakup coloration, and ability to maintain its composure at high volume levels places it up there with some of the best.
Jim Griffin had an array using twelve of the FR125SR version of this driver with an array of eight Aurum Cantus tweeters at the 2006 Lone Star Audio Fest. It was bi amplified using a DEQX preamp/crossover. I had no need for another line array at the time or it would have gone home with me. He also had a pair of bipole speakers using the eight ohm full range version of this driver, and I was impressed enough with the its sound to build a pair of those.
You men, like this? [message #24414 is a reply to message #24407] Thu, 22 May 2008 05:21 Go to previous messageGo to next message
Darkmoebius is currently offline  Darkmoebius
This guy's DIY project is ultra-extreme!
Re: You men, like this? [message #24415 is a reply to message #24414] Thu, 22 May 2008 17:06 Go to previous messageGo to next message
Anonymous
DIY rules.
But I prefer a different tweeter technology if you want an
extreme ultimate system. I don't even like the system design goals,
ie operating the driver down to a few hundred hertz. While this
is a great DIY project, be open to it's limitations.
Some of the specs that interest me are average, ie 1/2 Tesla gap
plus "According to Linesource's effeciency formula, they will be
right at 98 dB/W with 8 micron foil". This is boring specs.
You can find affordable commercial ribbons with 1T gap and higher
sensitivity right now. Plus, if you do parallel elements and can
live with a line array vs. line source, as low as 1.5khz - 2khz
crossover point, it would beat out this project pretty badly.
Last, I would never use low powered amplifiers to drive an ultimate
sound system.
103db/watt midrange and tweeter ribbons..bass line array [message #24416 is a reply to message #24415] Fri, 23 May 2008 01:04 Go to previous messageGo to next message
Scooter is currently offline  Scooter
A 0.4" wide x 90" long 5.8u Al tweeter ribbon with 1T could reach 103 db/watt
A 3" wide x 90" long 8u Al midrange riggon with 0.6T could reach 103 db/watt
Custom DIY bridge topology amps would be necessary to direct drive the 0.1-0.2 ohm midrange ribbon. 32 watts Class-A would seem adequate, and a high current delivery challenge
Five 15" woofers in parallel could match the 103 db/watt of the ribbons. A high 0.94 Qts like the Lambda Dipole woofers would save some baffle boost power. Should reach below 30Hz in most rooms.
Since this is Ultimate...an array of sealed bipole woofer stacked pairs would pressurize the room for 16Hz-30Hz.
ULTIMATE requires both midrange and tweeter ribbons + bass line array [message #24417 is a reply to message #24414] Fri, 23 May 2008 01:15 Go to previous messageGo to next message
ULTIMATE requires both 90" tall midrange and tweeter ribbons + bass line array of five 15" woofers.
ULTIMATE requires a 40K Hz tweeter ribbon.
ULTIMATE requires a full vocal range midrange ribbon.
Re: 103db/watt midrange and tweeter ribbons..bass line array [message #24418 is a reply to message #24416] Fri, 23 May 2008 03:54 Go to previous messageGo to next message
Anonymous
Meh performance. /lol
Re: ULTIMATE requires both midrange and tweeter ribbons + bass line array [message #24420 is a reply to message #24417] Tue, 27 May 2008 01:11 Go to previous message
Marlboro
I can't hear above 14khz.
Previous Topic: My ART Arrays
Next Topic: Question about magnetic flux modulation
Current Time: Tue Nov 03 11:42:05 CST 2026
